Ive created some mixes using the vdj software but am having great difficulty adding track numbers. it will only play as one whole mix. I would like to know if there is any way of dividing or adding track numbers to make it easier to skip through all tracks. thanks
geposted Sat 03 Feb 07 @ 8:25 pm
Option 1: Use the Auto-split on crossfade option in the recording options to automatically seperate tracks when the crossfader is moved fully to one deck
Option 2: Manually cut the tracks in VDJ as your mixing, using the little scissors button
Option Three: You can cut whole mixes up into pieces using Nero
geposted Sun 04 Feb 07 @ 1:53 am
