i have my sound system hooked up to play in sterio but everytime i connect my hercules and use it as my out put it transforms it to mono is there anyway to fix this thanxs......
geposted Wed 07 Feb 07 @ 8:16 pm
are you using a dual phono cable?
geposted Wed 07 Feb 07 @ 10:03 pm
i'm using the cable that came with it and a ground loop isolator......
geposted Sat 10 Feb 07 @ 6:50 am
what speakers?/amp?
geposted Sat 10 Feb 07 @ 4:58 pm
im using 4-warfdale pro 18s and 2 big cabnets with 2-15 in each with horns with wharfdale 1800 and 2800 amps but i run it through a 16 channel carvin mixer which gives me the option of sterio or mono and when i run it straight through my 2 channel mixer or from my headphone jack in my computer it comes out sterio but when i hook up the hercules it switches to mono....
geposted Sun 11 Feb 07 @ 11:27 pm
you need double phono to double phono cables
geposted Mon 12 Feb 07 @ 12:37 am
i use those already i put a 1/4 in. jack on my red wire and anothero n my white wire....
geposted Mon 12 Feb 07 @ 2:40 am
do you have another mixer or pc speakers to check if the console is working properly?
geposted Mon 12 Feb 07 @ 2:49 am
no...i have four different setups that we use but we hook em up the same way running through the carvin mixer i'm gonna e-mail the hercules company and see if they have any suggestions.....
geposted Mon 12 Feb 07 @ 8:27 pm
