Forum: Old versions
Topic: Video window won't stay full size
I'm setting VDJ up on a new computer. I have the second monitor set up as an extension of my desktop, hooked up via S-Video set at 800x600. I drag the video window over to the right, completely on the 2nd monitor, and maximize it. It works fine for 2 seconds, then the video window shrinks back down to it's original size.
I've tried every resolution setting on my video monitor. It happens with VOB files, MPEG1 and MPEG2 files. I've also tried hooking it up via DVI.
Thanks.
geposted Thu 08 Feb 07 @ 9:04 pm
your not supposed to drag the window preview over to 2nd monitor, but rather select the 2nd monitor as output in VDJ video setting tab, instead of that small window.
That will play videos full screen on your 2nd monitor ;)
Have both monitors connected before you boot up. Go to config>video>video output check the activate box, in the TV output pull down, select your video card. Your video should now go to your other monitor.
hi timthedj:
please visit:
virtualdj.com/blog/gj-dj
i have a first tutorial of how active full screen, sorry this site in spanish, but soon coming i inglish.
That the mixer become with you.
to get full screen go to config, click video, uncheck box marked hardware acceleration, good luck
