It is now available
* The CPU bug with my mapper was corrected in the new drivers of Hercules ;-)
* Cue button now works well
* You can now have a direct access to effects by writing the name of the plugin in the "String" field
(if you use sub-folders: name_sub_folders\\name_plugin)
geposted Sat 10 Feb 07 @ 2:21 pm
Very Very well done this is fantastic news for us all :)
geposted Sat 10 Feb 07 @ 7:23 pm
Thanks.!
geposted Tue 13 Feb 07 @ 1:09 am
Hey, I must be doing something wrong...
1. the mapper does not seem to auto load when VDJ starts up, rather you must select it from the 'effects' tab.
2. it does not seem to be responding to my settings, ie I have the SYNC buttons set to do SYNC_NOCBG but it does not respond.
This is in NON ASIO mode.
geposted Tue 13 Feb 07 @ 1:35 am
I see in the description that this is for use with teh 2007 version of the Hercules drivers, but does it work with older drivers?
I ask because the new Hercules drivers have a bug in XP (to be corrected 'soon') whereby the pre-listen channel doesn't work.
geposted Tue 13 Feb 07 @ 4:39 pm
yes this mapper will work with older drivers
the new drivers are aimed at vista only at the moment if your using xp stay with ur current driver
geposted Tue 13 Feb 07 @ 4:51 pm
Great work, thanks!
geposted Sun 25 Feb 07 @ 11:43 pm
@ All Hercules MK2 users
Don't update the driver of MK2, use the driver version of 2006 ( ftp://ftp.hercules.com/pub/webupdate/DJMk2/2006_CMK2_1.exe ), the 2007 driver is ok only for DJ console MP3.
If you don't want to have any CPU problem for dual core processor set audio option into this mode
In the example is possible to see le latest function added by DJcel, for button number one I have selected flanger Fx, for buttons 2 & 3 you can write the name of your preferred effect.
Have a nice mapping :)
geposted Mon 26 Feb 07 @ 9:25 am
The CPU bug was corrected with hercules drivers 2007
__________________________________________________
Now i have to add a way to save the strings in the file and maybe a combobox with all the audio effects
geposted Mon 26 Feb 07 @ 12:34 pm
Is it possible to change the effects parameters with the jog wheel?
For example, when the master tempo button is pushed, all effects parameters can be adjusted with the jogwheel, whilst turning it off returns the console to normal mode. If this were possible, the effects parameter would need to cycle, and not stop once reaching one extreme, like the Pioneer CDJ100/200 or EFX1000.
Thanks, Bagpuss.
Thanks, Bagpuss.
geposted Mon 26 Feb 07 @ 11:55 pm
I have to update the mapper... :)
I used the old one without image...
geposted Mon 05 Mar 07 @ 4:36 pm
