Forum: Old versions
Topic: TCV Question
mzackPRO InfinityMember since 2006
Why is the "play / stutter" button blinking on and off?
Everything worls good, just curious....also,
What are the best settings for my TCV setup? Im using the MK2 as my soundcard.
geposted Mon 12 Feb 07 @ 1:13 am
DME-CEOPRO InfinityMember since 2006
Good question..... Anyone??!!
geposted Thu 15 Feb 07 @ 7:34 am
DJ CyderPRO InfinityModeratorMember since 2003
Vdj is picking up vibrations in the needle. To make it stop enter the config menu then in sound setup click time code config, click the advanced view, then increase the silence slider until it stops, however if you like to do quick scratching you may not want to change these settings.
geposted Thu 15 Feb 07 @ 6:24 pm
thanx bro I figured it out last night in between sets at a club I spin @ due to the volume of the club system vs my own "lab" I kind of was like oh, o.k now I got it. but you mentioned something about scratching&settings. I've read days(not hours) on this forum with regard to the tcv settings, so what's your opinion?
geposted Sun 18 Feb 07 @ 7:00 am
