hi
i have seen this card and im not sure if ts ok for timecode,
its a esi maya 44
here are the specs..
24-bit 96/192kHz 4x4 audio interface ESI MAYA44– High Quality 24-bit 96/192kHz 4x4 audio interface. You would be amazed by its powerful and rich features MAYA44 offers. MAYA44 will satisfy beginners who just entering the world of digital audio, DJs using the PC audio systems, and music production professionals who produce music at his/her professional level with its power usage and reasonable budget. The features includes SPDIF Coaxial and Optical output, MIC input with +48V phantom power and Multi channel digital pass thru. The MAYA44 also supports ‘MI/ODI/O’ optional add-on card for additional digital inputs and MIDI interface. Features 24-bit / 192kHz D/A Converter and 96kHz A/D converter S/PDIF Coaxial and Optical Outputs Microphone Preamp with + 48V Phantom Power Simultaneous Full-Duplex Recording and Playback Shutter type optical output jack DirectWIRE 3.0 Universal Board (compatible for both of 3.3V and 5V PCI slots) Multi channel Digital Pass thru Supports E-WDM driver: MME, DirectSound, ASIO 2.0 and GSIF 2.0 OS: Microsoft Windows® XP/2000 Expansion Connector for additional Digital Audio inputs and MIDI interface(MI/ODI/O)*
thanks for your help in advance
dj jarvis
its a esi maya 44
dj jarvis
geposted Mon 12 Feb 07 @ 9:47 pm
that is a good card :)
geposted Mon 12 Feb 07 @ 10:24 pm
thank you...
ill get it so..
ill get it so..
geposted Mon 12 Feb 07 @ 10:31 pm
