when i go to run virtual dj it states...."unable to locate DLL"
then says something like c:/documents blah blah blah....what do i do?
i have my turns installed b4 but recently put my computer in the shop
SOMEONE PLEASE HELP!!!
geposted Mon 12 Feb 07 @ 10:06 pm
reinstall the demo
https://virtualdj.com/download.html
geposted Mon 12 Feb 07 @ 10:12 pm
i did re install the demo and still says the same thing
DINPUT8.dll is not fount
geposted Mon 12 Feb 07 @ 10:30 pm
what version of windows are you using and are you using the latest installer for the demo?
geposted Mon 12 Feb 07 @ 10:53 pm
im running windows 2000 pro..and now i got the one dll plugin installed but now it says
virtualdj_trial.exe - Entry Point Not Found
The procedure entry point GetRawInputDeviceInfoW could not be located in the dynamic link library USER32.dll.
geposted Mon 12 Feb 07 @ 10:57 pm
Wonder if it would be worth trying to 'repair' your windows installation? Insert your installation disc and follow the instructions.
Make sure you back up anything you want to keep, just in case!!!
Dunno if this will work, but it might be worth a try.
P
P
geposted Mon 12 Feb 07 @ 11:02 pm
the errors you are getting, are DirectX files...
So you need to update to the latest DirectX
http://www.microsoft.com/windows/directx/default.mspx
geposted Mon 12 Feb 07 @ 11:30 pm
Thanks Norway...and sorry Tsunami...:o(
P
P
geposted Mon 12 Feb 07 @ 11:33 pm
