I realize this topic has been beat up several times here but what I thought would be an improvement with the TCV issues with Version 4.2 has not proveen effective, or maybe my settings are off, but
I use the MK2 for my soundcard.......will the U46DJ make an improvement when it comes to scratching, there seems to be a "lag" issue and I think it might be the MK2 latency problem with this soundcard.
can anyone offer assistance with this?
geposted Tue 13 Feb 07 @ 10:19 pm
check my blog to see how to drop the mk2 latency to the 2ms
which kicks the u46s arse
geposted Tue 13 Feb 07 @ 10:29 pm
Sweet......where do I put the asio4all program, in program files, VDJ somewhere.......
sorry Im such a computer dummy!
geposted Tue 13 Feb 07 @ 10:39 pm
.....Also, it keeps coming up....Error, not enough channels??
geposted Tue 13 Feb 07 @ 11:15 pm
i dont thing tou need assio4all drivers for mk2.
thats why you have that error message.
use hercules drivers from your product cdrom or download drivers from hercules site maybe newer the ones you have.
geposted Wed 14 Feb 07 @ 2:24 pm
this is a hack , the asio for all drivers run at a massively lower latency
you need to choose on sound options
inputs : dual timecode
outputs : what ever you use ie external mixer
soundcard : asio
driver : asio for all , press properties and now on this screen enable the mk2 and dissable your internal card
press ok ,
now go to proformances and choose 2ms , on latency and press ok
now go to the sound config again and press timecode config , then press autoconfigure
this will fix it for you
check my blog again for pictures of each step if you get stuck :)
soundcard : asio
press ok ,
geposted Wed 14 Feb 07 @ 4:46 pm
