I have Virtual DJ - DJC edition.
At the moment Version 3.1 is installed but it won't let me update to 3.3. It says I already have this version installed.
What can I do?
Also, when i am cueing up a tune using the headphones, I have to keep my finger on the headphones button. Is there anyway I can press it once and it will stay on rather than having to constantly keep my finger on it?
Thanks
What can I do?
Thanks
geposted Sat 17 Feb 07 @ 3:30 pm
contact support
https://virtualdj.com/contact/
thats becuase you need to upgrade to pro for sustained use
comparison
comparison
geposted Sat 17 Feb 07 @ 3:52 pm
you can get a
discount as you bought the console
geposted Sat 17 Feb 07 @ 3:53 pm
I should still be able to get the updates though shouldn't I? It comes up that there is a new version to download when I start the program
geposted Sat 17 Feb 07 @ 5:53 pm
if you have already downloaded that update previously you need to ask for it to be enabled again at any rate ask support for a update file :)
contact
contact
geposted Sat 17 Feb 07 @ 5:55 pm
