I have just recently gotten my whole setup & I already had virtual dj.
I just bought 2 Numark TTx turntables
Numark DXM06 mixer
I bought a Soundblaster X-Fi Fatality soundcard & was told it was the exact same as the discontinued X-Fi Platinum card. I\'m very confused on how to hook every thing up to the soundcard. I read the info on the youre website but I\'m still confused. Where do I hook up the tables & the mixer. I see the line1 of the soundcard with a red & white jack, but where do I hook up the other turntable. On the line out they are smaller plugins do I need to buy a adaptor for the rca jacks. If you could thoroughly explain the process I would be very grateful. Thank you
Numark DXM06 mixer
geposted Tue 20 Feb 07 @ 6:18 pm
hi...
You need to connect one turntable to the phono plugis at the AUX in.
And the other turntable to the jack LINE IN. (you will need a phono to jack adapter)
That should work...
If you still have problems, you might have to do a small registry change (but dont worry,ACW will help you )
geposted Tue 20 Feb 07 @ 7:52 pm
