I tried to install my dj console mk2 in on ma dell laptop(inspiron 6400) windows vista ultimate but the virtual dj programm does't work when i run i get this message (the controler has not been detected please plug the controler and start virtual dj again) yet the machine is pluged in. guys i need some help here.
i get these message too when i try to install USB\VID_06F8&PID_B100&REV_0100&MI_07. has failed
geposted Thu 22 Feb 07 @ 3:39 pm
geposted Thu 22 Feb 07 @ 3:41 pm
you need the virtual dj patch and the new driver
Installation :
1- Uninstall the previous driver version: to do so, click Start/Settings/Control Panel. Select the Add or Remove Programs icon, then uninstall Hercules DJConsole Series drivers. Alternatively, you can simply launch this package: it will uninstall the previous drivers for you.
2- Restart your PC.
3- Launch this package to install the new drivers.
4- At the end of the installation, you may be prompted to update your firmware version if you have not already updated it. Please be sure to strictly follow the on-screen instructions for this very important procedure.
5- You are now ready to use your DJ Console or DJ Console Mk2.
Contents :
Driver Package Version 3.4.0.0
DJ Console Mk2 :
DJ Console Mk2 Firmware Version 13.7
Mk2 Control Panel Version 1.2.0.8
DJ Console :
DJ Console Firmware 35
DJ Console Control Panel version 1.4.2.5
Changes :
- Windows Vista x86 (32 bits) support.
- Fixes some ASIO minor issues.
- Fixes DJ Console MK2 firmware issues for Windows Vista optimization.
- Under Windows Vista, a Virtual DJ software update is needed (Available soon).
VirtualDJ 3 free update for Vista will be released soon for DJ Console MK2
No free upgrade is planned forVirtualDJ 1 DJC Edition. Since this version is not compatible with Windows Vista, DJ Console 1 users who want to switch to this operating system must either mix with another software, as MixVibes DJC Edition (fully supported in Vista), or they should buy an upgrade of VirtualDJ.
- Under Windows XP, Virtual DJ 3 & 4 will not have monitoring working with the MK2, an update will be available soon. Because of this issue this update is not recommended for XP users.
ftp://ftp.hercules.com/pub/webupdate/DJMk2/2007_CMK2_1.exe
Installation :
2- Restart your PC.
Contents :
DJ Console Mk2 :
DJ Console :
Changes :
geposted Thu 22 Feb 07 @ 7:28 pm
I'm having the same problem, but I'm using Windows XP. What do you recommend I do?
geposted Wed 07 Mar 07 @ 7:55 pm
reinstall using the xp driver
https://virtualdj.com/forums/66083/Hardware_Technical_Support/Common_Device_Drivers___.html
geposted Wed 07 Mar 07 @ 9:09 pm
