Forum: Old versions
Topic: BCD2000 - Heaphones and adjusting mid-treble-bass
When I adjust the mid, treble or bass on my BCD2000, the adjustment is heard fine in the speakers, but in the headphones it does not change.
Is this normal, can I get it to to reflect how I have set it with the knobs on the BCD?
Thanks
geposted Thu 22 Feb 07 @ 6:57 pm
yes it is normal. It's due to the BCD behavior. The headphone lines are plugged before Eq and Faders. It's the reason why you hear the sound as it is produced at BCD input.
I suppose it due to Behringer design.
I hope they will fix that with next BCD 3000.
Thanks
You could fix it easy with Registry Tool v1.5, just run the Registry Tool v1.5 and check the headphones close it and then run VDJ you will see that tnow you could heard the EQ on the headphones also... just download it from here https://virtualdj.com/addons/view.html?type=tool&page=2
Regards
Dj Quintana
i've done this before juliocqb, but i was getting errors loading tracks with VDJ. Has anyone tried this and working? I had to clean the registries first, uninstall and reinstall VDJ in order to make it work.
you don't have to clean any registry...just run this aplication and clip on the headphones sections, it works i had this working on my VDJ for sure ;)
Dj Quintana
I tried once more. Same things. Errors. The track seems like not loaded. It plays for a while, then stops. I get a blue screen with chinese, and i have to restart my PC. This happens ONLY when i change the EqHeadphones registry. VDJ doesn't work after that, unless i clean tha registries and reinstall VirtualDJ.
I don't know, this might happens only to me, but i dare not to try again. Registries are wicky things and could lead you to setup the whole thing from the start.
Worked for me! Thnaks.
Is there a page that explains what the other options do?
