I was trying to run vdj last night, and I thought I was suppose to:
Right click on desktop
Properties
Settings
I have run sonique before, but can't find where the settings are.
When I go into vdj,
config,
video,
there is only "window" under where you should be able to select "window" or "Nvidia 7600".
Any replies are appreciated.
Properties
Settings
When I go into vdj,
config,
video,
geposted Thu 22 Feb 07 @ 10:38 pm
you need to enable second monitor in Windows... FIRST
Right-click desktop, you to last tab (settings), and choose to activate 2nd monitor AS EXTENDED MONITOR for windows.
(the 2nd monitor usually needs to be connected, for Windows to allow this setting)
After that is done, the option to show video on the 2nd monitor shows in VDJ video settings
hope that helps :)
geposted Thu 22 Feb 07 @ 10:52 pm
Also, make sure your second monitor is attached before you power on your machine.
P
P
geposted Fri 23 Feb 07 @ 11:10 am
