After installation I get a missing export Shell32.dll:SHget folder PathA error. Followed by device attached is not functioning. (win98se)
I've researched and tried a few fixes found on the web but I still can't VDJ to load. Any suggestions from the brain thrust?
geposted Sat 24 Feb 07 @ 4:05 pm
i take it you are using 98 i recommend you use at least windows 2000 but for best results Xp
geposted Sat 24 Feb 07 @ 5:05 pm
Probably not a bad suggestion but that's not the issue. VDJ does support Win98 and from what I've seen on the internet this is not a uncomon or isolated problem. I thought I'd bring the problem here since VDJ will not load on this machine. Thanks anyway, maybe tech support will offer some insight.
geposted Tue 27 Feb 07 @ 5:26 pm
