Forum: Old versions
Topic: MK2 w/ VDJ 4.2 on XP SP2
I can\'t scratch nor preview. Anyone got a solution?
geposted Mon 26 Feb 07 @ 10:26 pm
yo dude check on options on the remote control tab , that the mk2 is enabled
if it is still playing up install the 2006 xp drivers
do not use the 2007 drivers for vista it has a slight preview bug
Thx it works like a charm.
Now I have another question.
What's the proper setting to get 3 audio output when using the Mk2 and a laptop?
what are you trying to do mate?
Trying to get the mk2 hooked up w/ my Numark DXM09 miixer
- 2 channel (deck left & right)
- 1 channel for samples output
Can you help me out?
