Forum: Old versions
Topic: TCV: Signal worse in 4.2 than in 4.0
Hi,
I use VDJ regualarly with TCV - it works great at all!
But I feel that after updating to 4.2 the signal stability and quality decreased after adding a few adjustments like TCV up/down. In 4.0 the signal was 100% nearly everytime, but now in between there are a lot of fluctations where sometimes it goes down to 33% and then again up. It still works good, but I don't feel comfortable with it mixing in the club.
I use an ESI with the 1.16 driver - even a driver's update to 1,20 did not show any enhancement.
Has anyone experienced similar problems? Solutions?
Thx for your resonds!
geposted Tue 27 Feb 07 @ 10:50 am
have you choosen autolatency on proformance options?
Yes, I did! Does it make any difference?
You need to reconfiger timecode in 4.2, as it has a new timecode engine..
In Performance tab, set you soundcard latency to auto
Then go to Soundcard, and timecode config. Press auto config.
Now your timecode has been reconfigured, and should work great
hope that helps ;)
