Just to verify a thing:
Do you have a line out or phono output on your turntable?
geposted Wed 07 Mar 07 @ 10:01 pm
djkapitalkev wrote :
meaning if i have my turntable stopped and the crossfadder to that channel it isnt silent its like a buzzing noise coming from the speakers which i am concerned about
If you're using a loptop cut the ground pin from the 110 or 220 plug or buy an adaptor without the ground pin. I helped alot of people with this. You don't need the ground from the power supply if you are grounding your mixer.
geposted Wed 07 Mar 07 @ 10:27 pm
R1.2 and beyond
R2.1 (latest)
This is what i get on the latest r2.1 version with the GEN3 vinyl.
R2.1 (latest)
geposted Thu 08 Mar 07 @ 2:26 am
just from the last pic the tc down slider is too low, not sure why it won't work for you, i would raise the 1/2 3/4 in's about 25%
get my updated miniscratch skin it just some nice new things added ;)
geposted Thu 08 Mar 07 @ 2:47 am
On which button 'Auto config" did you press for the last pic? The left one or the right one?
geposted Thu 08 Mar 07 @ 2:52 am
djcel....are you playing with me ?
geposted Thu 08 Mar 07 @ 3:04 am
Sorry but i don't have the mind to play at 3:11 am ;-)
Try on 1/2 of the maya 44 instead of 3/4
geposted Thu 08 Mar 07 @ 3:14 am
what ?
3/4 means bigger than 1/2
...do you want to put my levels up? i played with the levels up and down... and nothing...
Try to explain the first screen... (it works almost fine in r1.2)
geposted Thu 08 Mar 07 @ 6:04 am
Problem still not solved...
DJCEL was in my computer remotely doing some tests, but the problem still there.
Anybody else, please ???
I have this problem from the past 3 weeks and nobody came with an answer, maybe I have a bad GEN3’s.
In 4 hours from now I’ll be home and also on MSN.
Please somebody, put an end to this problem…
geposted Mon 12 Mar 07 @ 5:29 pm
Anybody?
geposted Mon 12 Mar 07 @ 7:06 pm
But why with a CONCORD style cartridge WORKS and why with the previous version my other cartridges are almost working OK, and you seen that remember ???
So you're telling me is something wrong with my maya44, hmm...
When i get home i will reinstall fresh VDJ and maya drivers...
geposted Mon 12 Mar 07 @ 8:34 pm
FunkyT, not sure what is wrong, the needles, or something else.
I've gotten another dj running fine on maya44.
Can you please make sure you do this, and in this ORDER too:
1) Go to soundcard settings and select the maya card for output
2) go to performance tab, and select AUTO for latency (IMPORTANT)
3) go back to soundcard, and choose timecode confing
4) choose auto config.
That should have all running well.
If you dont get 100% signal, adjust the sliders, specially look at gain and silence.
Not sure why you have this issue, seems to run so perfect with the rest ..
geposted Tue 13 Mar 07 @ 12:26 am
Thanks...
I did it ...after 3 hours of trying all the settings possible.(Playing ONLY with TC Up and TC Down)
I will post a picture to see the way my maya want's to work "ONLY IN MANUAL WITH THE NON CONCORD CARTRIDGE".
Once i switch to the Trackmaster II no problem, i go back to the Stanton 500/520/Craze (i don't now any more see picture above of my cartridges) they ONLY works in manual settings.
I'm going to bed, i had enough after 3 weeks with this GEN3's.
geposted Tue 13 Mar 07 @ 5:02 am
DJ Xeo wrote :
maybe atomix should sort it out and release 'auto config' options
auto config: GEN1
auto config: GEN2
auto config: GEN3
because lets face it, whats the point of auto config if it only works with the old vinyls?
either sort out auto config or put a "How to configure timecode manualy" in the manual
this forum is great but there are some things that should just WORK without having to study it (or atleast be explained properly in the manual)
auto config: GEN1
auto config: GEN2
auto config: GEN3
what a good idea ; )
geposted Wed 14 Mar 07 @ 12:41 am
