Ok so I can't find the answer I'm looking for, I read that the U46dj is compatible with vdj, but then I also read the Manual for the U46dj says that it's not compatible. So I need to know if the u46dj will work with vdj 4.2 or whatever the newest release is,and with the gen 3 tcv...I am about to purchase everything soon and want to make sure I make the right choice. Am trying to spend under 200 for the sound card, and this seems to be the only one I can find that's usb that is under 2 bills.
geposted Thu 01 Mar 07 @ 9:14 pm
u46dj works with VDJ, with drivers 1.014 or later ;)
And with the generic www.asio4all.com drivers as well
Its used by many users here, with timecode
geposted Thu 01 Mar 07 @ 9:19 pm
anyone know it is usb2.0, or if a newer version will be coming out? Does that even matter if it's usb1 or 2?
geposted Sun 04 Mar 07 @ 11:55 pm
