Forum: Old versions
Topic: Crackles from EQ Faders
I have problem with crakles and pops whenever I use the EQ-fader controls.
I have tried all the recommended PC optimizations and fixes I found in the forums:
1) setting system performance settings- visual effects off, virtual memory, processor scheduling, memory usage
2) updating BIOS, directX, audio drivers
3) removing unnecessary start-up services and programs- including networking and virus scan, firewall, spyware cleaning tools, etc.
4) Disabling all unused hardware - modem, wireless network,network card,firewire adapter,SD controller
5) Performing disc service - defrag and clean-up
6) trying various sound cards - on-board SigmaTel C-major, Echo Indigo DJ PCMCIA, M-Audio Connectiv USB (on-board audio disabled when using add-on cards)
7) Tried all possible combinations under 'Performances' tab for latency buffer (including auto), safe mode, overclock while all others items as set by default 'Fastest' settings.
8) Tried all available buffer sizes for ASIO configurations for Echo and M-Audio sound cards
My system is a Dell Inspiron 6000 with Pentium M 1.6 GHZ with 1GB ram, running Windows XP home ed. and 5400 rpm HDD.
I am running VDJ version 4.2r1.
Anyone have any suggestions that I have not tried?
geposted Sat 03 Mar 07 @ 12:22 am
MarkokoPRO InfinityMember since 2007
I have the very same problem. I have set hot keys for various crossfader & upfader functions, which eliminated the problem, so I think it might have something to do with the mouse pointer. It's kind of a pain though, and I need to figure out something for EQ crossfaders.
geposted Tue 13 Mar 07 @ 12:07 am
djcelPRO InfinityModeratorMember since 2004
Untick the option "safe mode"
geposted Tue 13 Mar 07 @ 12:52 am
Is your mouse PS2 or USB?? If it is USB it may be sharing an IRQ.
geposted Tue 13 Mar 07 @ 10:24 pm
USB. That may be the problem. Ironically, if I set the options for bbetter quality I get WORSE quality. Running at the second level preeset works best for me. The hot key solution has proved to be the best answer. I deleted the old Space Bar hot key and made it a crossfader. I also set Z as an EQ fader for one or more EQ sliders (depending on what I want to do). Since I have a habbit of hitting the key to the beat, I have figured out the numbers required to get the fader to move all the way accross in 32 beats (+/- 127) or 16 beats (+/- 254).
geposted Thu 22 Mar 07 @ 10:14 pm
Try a PS2 mouse if you can and let me know if that was it.
geposted Sat 24 Mar 07 @ 12:13 am
