hi, i have the herc controller, the one without the built in soundcard, i have a question about why when i slide the crossfader, turn a knob and slide the volume controls i get a rumbling noise that sounds like someone blowin a raspberry (ie farting) through the speakers?
any ideas on settings etc that i should change to stop the noise as it proper messes the quality of the mix...sure you all know that already!
L8rz...
DJ Gigilo.
L8rz...
DJ Gigilo.
geposted Sat 03 Mar 07 @ 4:24 pm
          what actual card do you use for sound?
    geposted Sat 03 Mar 07 @ 8:01 pm
          i am using 5.1 soundblaster 24bit external soundcard m8,
been playin roound with the settings...still getting the rumbling noise, only seems to happen after an hour or so of mixin...might just be a simple change of computer setting or something, what you reckon m8?
geposted Sat 03 Mar 07 @ 8:59 pm
          alrighty how much ram do you have :)?
    geposted Sun 04 Mar 07 @ 12:58 am
          2gb
    geposted Sun 04 Mar 07 @ 3:55 am
