Forum: Old versions
Topic: Choosing a Motherboard
I need to replace my MOTHERBOARD and I could us all the help I can get ... I running MP3's, karaoke and looking into video...
I have the following hardware to be integrate onto the board..
Processor
Intel Pentium® 4 631 Processor Prescott 3.0GHz, 800MHz FSB, Socket 775, 2MB
Ram
OCZ OCZ28002048ELDCGE-K 2GB Kit DDR2-800 PC2-6400 Enhanced Latency Gold Edition Dual Channel Memory
Video Card
Sapphire Radeon X1600 PRO PCI Express 512MB DDR2 Video Card w/TV-Out, DVI & VGA
I would like to keep the coast down and quality up so please post ideas and links, no ebay links or check these out please, just specific boards.
I have a strong power supply & a nice case to put the board into...
Thanks
geposted Sun 04 Mar 07 @ 5:23 am
geposted Sun 04 Mar 07 @ 8:59 pm
sbangsPRO InfinityMember since 2004
geposted Sun 04 Mar 07 @ 10:10 pm
geposted Mon 05 Mar 07 @ 1:06 am
geposted Mon 05 Mar 07 @ 1:11 am
mp3jrickPRO InfinityHonorary MemberMember since 2003
Are you trying to find the cheapest one you can?
geposted Mon 05 Mar 07 @ 1:16 am
DJ Marcel_1 wrote :
paulettecerra wrote :
What about this one
Intel Desktop Board D955Xcs Socket 775 BTX Motherboard
http://www.geeks.com/details.asp?invtid=D955XCS
Looks good but is your power supply ATX format (connectors) or BTX?
Dam.. will not fit my case.. thanks ATX
I had D955XBK
geposted Mon 05 Mar 07 @ 1:27 am
I really don’t understand chip sets stuff at all.. I copied Everything in my computer from another VDJ member.. Intel kept coming up as the best so I went on ebay and got the Intel 955XBK or $49.00.…
What are your thoughts on this one ..
geposted Mon 05 Mar 07 @ 2:10 am
Paul - Asus makes the Best "aftermarket" motherboards, Very reliable, very well made.
If you're only replacing the MoBO spend a little bit - at least $100.00 CDN (85.01 USD)
Remember this is the Frame that all your stuff plugs into - cheap out at your own peril
You never mentioned if you are looking for a micro ATX or regular ATX size format
And your power supply - is it a standard component P/S - or is it proprietary? If it's out of a Compac/HP or a Dell system - check your conectors, they might not be aftermarket standard - you might have to cut and solder.
I went through this when I wanted to upgrade my desktop pc. It was a Compac presario P3 750MHZ, The ATX powersupply was too weak for the new processor (200watts) and the cables for stuff like the front usb's and headphones were all slightly different some were very small compared to the new board some were 3 wire instead of 2 others were 4 instead of 3.
In the end I ended up haveing to buy a new tower - A home desktop tower is cheap as all hell, But small portable cases are not so cheap.
I had a buddy that I helped out tell me this stuff or I'd have been sunk.
He's a biker - I made his chopper run better - he installed the wrong carb - too much CFM ran like shit, changed the carb and adjusted the idle settings - and boom he was off. He's also a microsoft tech now, make more money than I do - Which might explain the tricked out Harley Police special he rides.
geposted Mon 05 Mar 07 @ 7:13 am
The power supply is Norwood Micro 500 watts
Size,, ATX , , The 955XBK fit perfectly
Asus I seen them every ware.. . What board do you recommend…????
geposted Mon 05 Mar 07 @ 2:39 pm
ATX (12.00 inches by 9.60 inches
geposted Mon 05 Mar 07 @ 3:03 pm
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2366120&CatId=1572
This is the bad boy I'd look at
has everything you need
high def audio - 8 channel even (if you don;t use timecode)
sata support
firewire
no video so your pci express card will be your whole world for that
146.55 USD - REasonable for a motherboard like this
has the advantage of being the lastest and greatest socket for duo cores - so if you decide to get a duo core is just a CPU swap as opposed to a board/porcessor swap
geposted Mon 05 Mar 07 @ 3:40 pm
Are far as audeo,, are you saying that the onboard sound card is great or just ok???
geposted Mon 05 Mar 07 @ 3:58 pm
I use my motherboards onboard audio - because I use a DAC2 so no need for timecodes
It's a 5.1 surround audio so three channels are easily used:
1/2 -left deck (channel 1 on my mixer) 3/4 - right deck (channel 3 on my mixer) 5/6 - samples and pre-listen (channel 2)
I would compare the quality to a mid-level soundblaster card, very good but not spectacular.
I've been using the sound on my new mobo for about 6 shifts at the club (aprox 40 hours) sounds nice even at 105db
All the boards I own are mirco-ATX, case size determines that.
Good Luck
DJ Marcel
Purple Onion NightClub
geposted Mon 05 Mar 07 @ 6:55 pm
geposted Tue 06 Mar 07 @ 3:32 am
Asus COMMANDO Intel P965 Quad Core GLAN/LCD
THIS TYPE OF MOTHER BOARD I RECCOMEND, CAUSE FOR MULTI PROCESS THIS IS THE BEST
geposted Wed 07 Mar 07 @ 12:11 pm
