i want 2 buy timecoded vinyl,but i dnt hav a asio sound card.
So i downloaded the free software asio4all and it works.
I can play a normal record on my table and vdj picks it up as it would with a timecoded 1.
It should make a noise but u have to use the asio4all software to use the timecoded vinyl so a cant use my soundcard to hear it.
Is there any way i can not buy a new sound card but use timecode vinyl?
thanks
thanks
geposted Sun 04 Mar 07 @ 5:34 pm
what card do you have
geposted Sun 04 Mar 07 @ 9:36 pm
just a average one its a sigma tel i think what should i do?
ps it has a mic input and a input and more like black one and green and yellow i think will they work
geposted Sun 11 Mar 07 @ 9:54 pm
you need a card with dual stero input to use two timecodes
or two cards like this.
geposted Sun 11 Mar 07 @ 10:14 pm
I kinda have the same problem, but i dont get any sound through my turntables, iv also orderd timecoded vinyl.. I have no soundcard tho. I guess thats the problem.I have a BCD 2000, can i use that as a sound card?
geposted Sun 11 Mar 07 @ 11:28 pm
https://virtualdj.com/blog/juliocqb/
check this blog :)
check this blog :)
geposted Sun 11 Mar 07 @ 11:55 pm
yea iv read that, but i have a problem. If you look down on the page it says about click on : midi_Bcd2000
For some reason i havent got it there..... No idea why. U have any idea how to get that?
geposted Mon 12 Mar 07 @ 12:51 am
if you need a soundcard and dont have the software or tcv's then it might be wise just waiting for the numark virtual vinyl package so you can get everything you need all included in one box.
geposted Mon 12 Mar 07 @ 1:22 pm
