Forum: Old versions
Topic: full screen settings
deandjHome userMember since 2007
hello
im having trouble fitting the program to fit full screen... I have the "active wave form" window at the top as normal and at the bottom of the the sreen, when i move my burser to the bottom it hides behind the "active wave form" window (a bit like a split screen) how do i solve this ???
geposted Mon 05 Mar 07 @ 8:41 pm
PionaraPRO InfinityMember since 2004
What skin are you using for the program, and how do you have your screen resolution set???
At 1024 * 768, my default VDJ skin fits my screen nicely.
P
geposted Mon 05 Mar 07 @ 8:46 pm
