I am using a ultra-light rig consisting of a 'tweaked' tablet PC, Hercules DJ console MKII, a 4 fan Laptop cooler, a UHF wireless mic, and an 80GB iPod (as a backup so I can run to my car to grab another laptop in case of catastrophic failure).
PROBLEM: I have new club gig that does NOT have a booth monitor. I was able to work around it by bringing my $300 Apple HiFi speaker with me. Yes it is a little OVERKILL but it works for now without splurging for a dedicated monitor.
All went well until later in the evening when I turned it up too loud and the speaker shut down. I thought I FRIED the HiFi, but later found it shut down for thermal protection and was fine the next day.
--> What I need to do is to find a way to cut the bass going into this speaker so that I can crank it up louder as the night goes on.
1. Does anyone know of a device that I can buy that will do this?
2. Anyone good with electronic circuits? I could whip a filter up with some radioshack parts and build an in-line bass filter.
3. Is there a booth monitor out feature for VirtualDJ and can the software strip the bass out just for this channel? Maybe I could use the onboard sound card?
The idea here is to carry as little as possible. I do not want to drag around a EQ just for a booth monitor! Anyone got any ideas or schematics?
Regards,
WirelessDJ
Regards,
WirelessDJ
geposted Tue 06 Mar 07 @ 3:45 am
          Nice compact set-up there!
I think your idea of making a filter might be best if you know how to.
Otherwise I guess you'd be just looking at a more powerful speaker. :)
Also, I don't have the mk 2 so I don't know, but if it has a "headphone split" fucntion, you could try using that. A "split-cue" style headphone setup is when one song comes out the left ear phone and another song comes out the right ear-phone, then you might not need a monitor so much!
Hope you come up with an answer to your problem. :)
geposted Tue 06 Mar 07 @ 3:55 am
          Hey Wireless
Good to see you on this forum. It been a while I heard from you since the BPM Studio Days
DJ Angel S
DJ Angel S
geposted Tue 06 Mar 07 @ 4:04 am
          If you are running useing the Ipod docking speaker like a booth speaker - does the ipod have to be hooked up for noise to come out - or does it have a line in?
    geposted Tue 06 Mar 07 @ 4:10 am
          i thought i saw some inline passive highpass filters that will plug inline on your input to the hi-fi. if i recall correctly, they were at partsexpress.com
          No iPod needed.  Apple HiFi has line-level input, optical-in, and iPod dock on the top.  And also runs off of 8 'D' batteries (However, it is not as loud as when it is plugged into AC).  It's a perfect little speaker for home and portable use.
High pass filter? Good idea! Anyone know how make one up?
geposted Tue 06 Mar 07 @ 4:24 am
          No need to manufacture any.  Like anewsome said, get inline highpass filters.  They are usually RCA type.  Try www.crutchfield.com.  I think I saw them there at one time.
    geposted Tue 06 Mar 07 @ 8:58 am
