Forum: Old versions
Topic: FAST TRACK PRO
wondering what config I need to send 2 stereo tracks out of the m audio fast track pro..so i can preview tracks and run two channels on my mixer...any advise
thanks
shaggyya
geposted Tue 06 Mar 07 @ 4:39 am
sbangsPRO InfinityMember since 2004
choose
inputs : none
output : 2 line mixer
card : fast track pro
geposted Tue 06 Mar 07 @ 11:34 am
For outputs The only choices I have are:
single output
headphones
external mixer
3-lines mixer
and in the initial soundcard drag down...no choice for fast track pro..
If I try the external mixer with 2 cards listed...it will play correctly..but the sound on 3 and 4 is very poor...I must not have it hooked up right...Am I looking in the right place???
thanks for any help.....what do you think?
geposted Tue 06 Mar 07 @ 8:52 pm
try 2 cards still but on proformance options try
"autolatency"
geposted Tue 06 Mar 07 @ 9:56 pm
If it only shows up as "Usb Sound Card" and not "Fast Track Pro" the drivers are not installed correctly and you will not be able to use 4 channel or ASIO mode
Rusty
geposted Tue 06 Mar 07 @ 11:20 pm
i will try tomorrow. it does show up as fast track pro...thnaks i will check back tomorrow with results
bill
geposted Wed 07 Mar 07 @ 4:28 am
It works...but now there is a serious click/song drag in the right deck and sound degredation...any thoughts
I am running an
AMD turion 64 duo core
1 gig of Ram
switched from Vista to a stripped XP (soundcard wasn't vista ready)
running off a Western Digital external 120g Hard drive with like 10,000 songs
also...when I switch back to simple mode...it skips while automixing
help!!
bill
geposted Wed 07 Mar 07 @ 10:50 pm
fixed simple mode problem by adjusting some items in performance tab....channel b still sucks in dual mode though...advise?
thanks
bill
geposted Thu 08 Mar 07 @ 2:00 am
