Posted Tue 06 Mar 07 @ 11:03:22
if the DMC2 is 299 and the version of Cue is LE , which will not allow the video to be sent from the computer... The upgrade is 299. Then why should i purchase the Cue software... will the virtual dj software work just as well. it was a bit misleading but actually I didn't expect to get working software for my karaoke shows / DJ shows and a controller for 299.00.
I know I am a non licence user. I have been learning with the software for about two months but not all the time. Some of the features added to recent upgrades are making me want to buy the program. Virtual folders (I just found out about last night , while researching Cue software) I like the dmc2 , it said it had a video fader, is this music as well, like a mixer/ fader?
I would like to review some other simple skins if possible. I would like simple controls with video windows. thanks again
I would like to thank all those who have been part in answering my questions and concern. While I am a No licence user, I have been treated with respect, while honestly i have used a cracked version, I intend to purchase the full version , I know there are others out there that might be doing the same , and just realize that there is a whole community of DJ's working to make your performance better , support it financially as well as with knowledge.
The next time you see me , I will either have Cue or VDJ. I would like to use the DMC2 controller. Many thanks Michael
when i used pcdj, I would make a waitlist and then put the songs in order that I wanted them played... I can do the same with Virtual folders by opening the virtual folder and then taking songs and creating a playlist , then save playlist in the order i wish... is this correct
geposted Tue 06 Mar 07 @ 6:06 pm
