I have a strange problem that has popped up twice in the last month while performing. I'm using VDJ professional v4.2 on a HP Pavillion DV9000 laptop with Intel Core Duo 1.66 processor and 2Gb of RAM.
When I'm mixing and use the BPM sync feature, sometimes (twice) it doesn't reset on the next song. If the new song's BPM speed is detected wrong (even though I know the songs will mix), the pitch will start to change automatically in the middle of the track, and I can't stop it. If I click on the zero to reset the pitch, it shakes like it's trying to reset, but won't do it. The pitch will stay messed up on every song played on that side (side 2, or the RH side, if I remember correctly). The only thing I can do to reset the pitch is close and restart VDJ. Then it works fine again. Any ideas?
Curt
Curt
geposted Wed 07 Mar 07 @ 8:21 am
I experience that problem too. Maybe there's have a problem on the software there's a bug on it, not perfectly design. somebody help us to correct this problem... there will a be hustle on it, for example when ur in gig....and mixing then problem happens u have to restart ur VDJ... to play the VDJ normally again. there's a hustle on it... pls help us to correct this problem... Tnx
geposted Wed 07 Mar 07 @ 1:39 pm
bump... No ideas, huh? Anybody?
Curt
Curt
geposted Fri 09 Mar 07 @ 8:27 am
