I know this isnt a Virtual DJ question but i know there are alot of people here who have alot more computer knowledge than me and i need help.  I am tring to transfer my music files from one laptop to another and i have a router at home so i want to connect the two laptops so i can just share the folder and send it that way!  i have tried but cant seem to get it to work.  is there a step by step guide anybody knows of on how to do this?
    geposted Wed 07 Mar 07 @ 9:36 pm
Its not that hard, but a bit technical...
Read this guide:
http://compnetworking.about.com/od/homenetworking/Home_Networking_Setting_Up_a_Home_Network.htm
And I'm sure you'll have it up and running ;)
geposted Wed 07 Mar 07 @ 10:25 pm
          heya , im a system and network enginer
so if u need any advise gimmie a shout my msn is on my blog
geposted Wed 07 Mar 07 @ 10:42 pm
           Ok i dont know the right terms so bare with me!  I have a modem which i have a wireless router connected.  I do not have any computer connected directly to the router im just using two laptops which connect to the router with wifi to access the internet!  What i want to do is connect the two computers so that they can share files.  I have tried setting up a home network and pinging the computers but they do not recognize one another.  Now they both do accress internet but on both of them the LAN has the little red x on it.  My question i guess is do i need them to actually be connected to the router with an ethernet cable for them to network?  They both connect to the internet fine...   i have looked at tuturials and everything and it makes it out to be so easy but yet i follow the steps and im not sure if im doing it right or what!       (LAN = x   but wireless is ok does that have something to do with it?)
    geposted Thu 08 Mar 07 @ 10:05 pm
          make sure the computers are in the same work group
http://www.lockergnome.com/nexus/windows/2005/11/08/add-a-computer-to-an-existing-workgroup/
geposted Thu 08 Mar 07 @ 10:37 pm
