Forum: Old versions
Topic: M-Audio Firewire Audiophile
Hi Guys,
Haven't posted in some time, been busy doing the working life etc etc.
I am still trying to work out my setup and making sure everything will work just the way I want it prior to splashing out on purchasing Pro - so far the demo and BCD2000 are working fine, now its on to the sound card.
Tell me guys,
http://www.maudio.co.uk/products/en_gb/FirewireAudiophile-main.html
Is this sound card going to be able to do the following in VDJ.
Laptop -> Firewire Audiophile RCA L+R Output 1 -> Mixer CH1 L+R -> House mix/PA etc etc
Firewire Audiophile RCA L+R Output 2 -> Headphones mix.*
Now my biggest issue is how am I supposed to get the headphones plugged in to the output 2 of the sound card given that the outputs are RCA?
Cheers,
Steve.
geposted Thu 08 Mar 07 @ 6:00 am
I failed to mention that BCD2000 is working as a controller, not a sound card. I am still trying to get the jogwheel to work the way I want. So far i can only get it to work on scratch and in one direction lol.
If only both MIDI option and BCD2000 native support can run at the same time so I could custom map the dead controls on the bcd as a result of the native support being enabled.
wesky wrote :
... Laptop -> Firewire Audiophile RCA L+R Output 1 -> Mixer CH1 L+R -> House mix/PA etc etc
Firewire Audiophile RCA L+R Output 2 -> Headphones mix.*...
When you say mixer, you mean you have a mixer (or will buy), or do you mean the BCD2000?
You will plug the headphones in the mixer, not the sound card.
The sound card is ok.
A mixer as in normal DJ mixer. The BCD is just purely MIDI controller.
Although, I played around last night and found a way to use the BCD2000's soundcard as my headphones out and i use another soundcard as the house mix.
Cheers,
Steve.
