Forum: Old versions
Topic: tcv question
TreZorHome userMember since 2004
if you are running vdj and tcv and when you want to switch to normal vinyls which soundcard is the best then?
edirol fa66 or better go for tor connectiv interface?
does both those card have built in pre amps? and a switch to change from phono to line-in?
geposted Thu 08 Mar 07 @ 4:05 pm
