I need to make a demo, and if you know any good software let me know + that uses m4a. THX
geposted Thu 08 Mar 07 @ 7:10 pm
My cousin just bought me a copy of Sonar 6 as an early b-day present. It's expensive but well worth it. Do a search on youtube for "sonar 6 audiosnap" (without the quotations), it's just amazing the possibilities what this new version of Sonar can do;^]
geposted Thu 08 Mar 07 @ 7:21 pm
Technically Sonar isn't remix software. Sonar is more of a multitrack recording program, like ProTools. (I use and like Sonar though.) You might have more luck with Ableton Live, which is made for remixing and live performances.
geposted Fri 09 Mar 07 @ 3:38 am
Yeah, sonars no good for live remixing, but the new Sonar 6 does have powerful beatmatching and time stretching, the audiosnap feature makes tightening the mix up a breeze. Sonar 6 as far as multitracked remixes go gets the job done and then some. Great all around production software;^]
geposted Fri 09 Mar 07 @ 5:31 am
Everybody uses Sony Acid Pro 6 (PC) .. Megamixing, bootlegs, mix.. but not for live-mixing..
Advanced and user-friendly..
Luv it..
Luv it..
geposted Fri 09 Mar 07 @ 9:48 am
Thanks
geposted Fri 09 Mar 07 @ 4:45 pm
is there any thing similar to Mixmeister for PC. just drag and drop beatmatch and mix + m4a file format.
Thanks
Thanks
geposted Fri 09 Mar 07 @ 5:08 pm
You can do that with Albeton Live.
geposted Fri 09 Mar 07 @ 8:54 pm
