Hi, I was ready to order my PA package today when 90% of the PA packages went discontinued. I called them and they werent very helpful as to whats going on. I'm interested in picking up a good pa package with speakers, amp, mics, and stands but I'm now stuck on where to get it. Musicians friend seemed like they had the best deals. Anyone know whats going on and why these things arent available? I was looking at the Yamaha Package item #630199...
geposted Fri 09 Mar 07 @ 4:17 am
Have you tried Sweetwater, B&H Photo and Zsounds? You could try Carvin if you really want a high end system. Chances are though if musicians friend has discontinued these packages then there's likely to be new ones addded very soon;^]
geposted Fri 09 Mar 07 @ 5:35 am
whats yor goal? how big of a room? how many people will occupy? what kind of music? whats your budget?
best budget deal you will find:
http://cgi.ebay.com/2-Legion-PA-DJ-15-18-mains-subwoofer-speakers_W0QQitemZ130088314942QQcategoryZ47094QQssPageNameZWDVWQQrdZ1QQcmdZViewItem?hash=item130088314942
-just match it up with one of these amps (mono) one channel for subs the other for highs
http://www.behringer.com/EP2500/index.cfm?lang=ENG
-this eq/crossover (mono) one channel for subs the other for highs
http://www.behringer.com/GEQ3102/index.cfm?lang=ENG
this is the best bang for buck system.
I have 4 of those legion sound 15's. they will surprise the hell out of you.
geposted Fri 09 Mar 07 @ 8:19 am
