I have all of my correct information plugged into VDJ... and it even says it's broadcasting. I have a playlist in que, music playing... yet looking at the Live365 page, it says I have no songs in que and it doesn't broadcast anything. After the initial connection, my computer quits streaming music... hours of searching has yielded no results. :-/ Any ideas?
    geposted Fri 09 Mar 07 @ 7:06 am
          do you need to turn the live 365 server on? before you can stream
have you unblocked your firewall on the ports it needs ?
geposted Fri 09 Mar 07 @ 11:27 am
          The server's on... And even with the firewall down it does the exact same thing. There isn't even a router in the picture that could screw things up. GAH!!
Frustrating :(
    Frustrating :(
geposted Fri 09 Mar 07 @ 6:27 pm
          confirm you have the right ip and port for the server
what is ur pc spec
    what is ur pc spec
geposted Fri 09 Mar 07 @ 6:45 pm
          They are correct. It's the exact same information the owner of the station uses for his broadcasting on SAM. It shows that I am "connected" to live 365, but it claims my playlist is too short, when I have beyond the minimum tracks. It'll conenct, but not stream.
    geposted Fri 09 Mar 07 @ 7:14 pm
          what is the exact message you get?
    geposted Fri 09 Mar 07 @ 9:49 pm
          The error is through live365, and says that my playlist is too short. I'm being told this through the owner, who is in another state. He and the live 365 support team seem to think that it's my firewall, but I have the ports open for it.
    geposted Sat 10 Mar 07 @ 6:23 am
