Hi,
We are planning to buy VirtualDj and use it in a nightclub:
In hardware requirements i read:
"DirectX compatible soundcard (with front and rear separate outputs)"
Could you suggest some readily available(so i can buy from BestBuy/CircuitCity) soundards? What is "front and rear separate outputs"?
If i get a PC from a store, do they usually come with the required sound/video cards?
Can a laptop be configured to have the required specs? Or a desktop would work better anyway?
thank you in advance.
geposted Fri 09 Mar 07 @ 4:43 pm
