Forum: Old versions
Topic: EQ Bug
Rem1xHome userMember since 2006
when u kill highs or whatever (highs, lows, mid), a track takes forever to load, or most of the time it never fully loads.
mess with the EQs and the program starts acting really really buggy.
no problem with v3.4. problem with v4+
geposted Sat 10 Mar 07 @ 6:44 pm
that's with all files, even the scanned ones;
played around with max load;
played around with performance tab.
'wont work with one of the 2 soundcards. will barely work fine with the other one. latest updates installed.
v4+
geposted Sat 10 Mar 07 @ 9:56 pm
1.6Ghz
768MB mem
256MB graph
geposted Sat 10 Mar 07 @ 9:57 pm
You're member since September 9th 2006. I remember you the trial version is limited to 20 days. So that means you're now using a cracked version. Cracked versions often contain bugs. Please buy the software from our website before saying it's bugged.
geposted Sat 10 Mar 07 @ 10:51 pm
