Hi.
Terribly sorry if this topic was already posted or if the question is too "juvenile".
Can I use the software Virtual DJ to play my MP3 files with my CDJs? I would connect the mixer on the PC (via an Audio Board/Interface). Is it possible?
If positive, I'd like to know if the answer is good. If it really have a good sensibility, i mean, if it is the same (or almost), same thing as playing with the CDs.
Also, it would be good to know which is a good PC configuration to run the software with a perfect performance on the CDJs.
Thank you very much!
geposted Sat 10 Mar 07 @ 8:08 pm
https://virtualdj.com/products/timecode/
check this
burn 2 copies of this to cd as an audio disk
https://virtualdj.com/products/timecode/VDJTimeCode.mp3
check this
geposted Sat 10 Mar 07 @ 8:36 pm
Hey skyfxl !!!
Thank you very much for your answer.
I realized that is plenty possible to use Virtual DJ with my CDJs.
But now I'd like to know if someone here at the FORUM have already tried to work with this setup.
Please tell your experiences, if it really have a good stability, if the answers on the jogs are as quick as it is on the CDJs. A 512 RAM laptop could run the program with full response?
Tks again for the support!
geposted Sun 11 Mar 07 @ 5:53 pm
i meant if the answers on the jogs are as quick as it is playing with CDs...
i can't resist, i have other questions. this software seems to be so cool !!
this is the audio board i intend to use with Virtual DJ :
http://www.zzounds.com/item--BEHUCA202
is it good? compatible?
peace
peace
geposted Sun 11 Mar 07 @ 6:09 pm
Currently, I'm operating VDJ using CDJ 1000 MkIIs. So far, it's been really reliable although I've used it all of 3 times and only during 1hr sessions. No hiccups just yet and none that I can see.
The jog works almost as quick as a CDJ running a regular CD with a very slight delay that wasn't a factor to me during regular cueing and beat matching/mixing. And by slight delay I mean barely noticeable. If you've never used CDJs with regular audio before, you wouldn't even know the delay existed.
I'm not sure if your system specs are good enough to run with the same amount of responsiveness than I'm getting simply because I've never tested the system with 512 mb of RAM. Hopefully someone else can answer that question for you.
Also, the cueing works similarly to CDJs in Vinyl mode as opposed to CDJ mode meaning that the audio doesn't stutter when cueing. It's either dead silence during pause or "vinyl" sound while jogging.
geposted Mon 12 Mar 07 @ 6:08 am
