Hi
Finally I have downloaded the demo version and am trying it out but want to go slow but sure. My question is do I install gigaport soundcard driver or do I let windows load the soundcard. I am ex pcdj user and was using window's driver for soundcard and also can I use DAC 2?
Thanks and hope to join pro user rank soon enough
geposted Sat 10 Mar 07 @ 8:35 pm
          Gotta use the Gigaport drivers, otherwise you won't be able to use more than one set of channels. You should be able to use the DAC with the demo version without issues.
    geposted Sat 10 Mar 07 @ 8:49 pm
          install the gigaport
dac is supported :)
    dac is supported :)
geposted Sat 10 Mar 07 @ 8:55 pm
