Well, my verdict is in.
I was apprehensive at first, but after one minor fix (regarding the database and admin privledges), all I can say is WOW!
I mean WOW!
I mean WOW!
geposted Sat 10 Mar 07 @ 9:51 pm
Wow what, please elaborate so i can fix mine?
geposted Sat 10 Mar 07 @ 11:13 pm
if you cannot read your database in windows vista try loging in as administrator
or go to users on control pannel and raise your self to admin rights.
geposted Sat 10 Mar 07 @ 11:26 pm
Or right click the program icon and assign your self admin privledges.
What issue are you having, perhaps I can assist.
geposted Sun 11 Mar 07 @ 12:30 am
Can you tell what is the rest of the gear you using with it, thanks
geposted Mon 12 Mar 07 @ 1:25 pm
Ronny just summed it all up with this statement..... its time to ditch XP and go VISTA people.... it so ROCKS with VDJ...!
geposted Mon 12 Mar 07 @ 11:07 pm
Word is good here. Switched to vista biz last week, totally rocks. Everything in vista is much better. Videos are great audio is great. Can't ask for much more. Only thing i did was turn off the visual effects on the windows. No other tweeks. My vista score on my testing machine was 4.6
geposted Tue 13 Mar 07 @ 4:24 am
very nice near perfect :) score =D
geposted Tue 13 Mar 07 @ 10:27 am
whatya mean by turning off (how?) visual effects in windows?
geposted Tue 13 Mar 07 @ 7:17 pm
If you got a decent enough memory on your graphics card (256+dedicated) then you shouldn't need to turn off your visual effects.. If not go to appearance and personalization from there you can turn your visuals on and off
geposted Tue 13 Mar 07 @ 11:41 pm
I probably didn't need to turn it off, its sorta habit from the days of xp skipping audio when you moved around in windows. Like I said I vista flys for me. I'm very pleased with its performance. I got the upgrade version for biz and found out you can do a clean install with it which makes it even better.
better then that, I found out I could force a lot of old xp drivers to work, even though there aren't vista drivers, ie my wireless card and my soundcard.
geposted Wed 14 Mar 07 @ 3:20 am
