hey everyone my question is when using tccds ..can i pitch bend using the jog on a cdj 800 ? can i use the cue and play buttons too ? and how about the auto loop buttons on the top left side of the cdj 800 can i have them work with the software too ? please help me out here cuz i don't really have access to this virtual dj here in israel i think nobody uses it here i would like to be the first but mixvibes and scratch play the main roll here so i cant test virtual dj myself.
another question is when using the master tempo ..would i be using the master tempo of the cdj 800 or virtual dj ? bcuz i saw a vid on utube while using another program ( i dono if im supposed to be saying names here but ill say it for the sake of learning ) serato scratch , the master tempo was being used from the cdj and not the program ..i think thats gr8 as it means the work gets divided between the pc and the cdjs ..does it work like this with virtual dj ?
i'd appreciate the help thanks.
geposted Sun 11 Mar 07 @ 12:06 pm
if you use tccd , the software follows the instructions you give it :)
for more info check
https://virtualdj.com/products/timecode/
to make tccd
https://virtualdj.com/products/timecode/VDJTimeCode.mp3
download this and burn 2 copies as an audio cd
for more info check
to make tccd
geposted Sun 11 Mar 07 @ 3:08 pm
Hi,
if you use a timecode cd, then I'm pretty sure that you need to turn off master tempo on the cdj or it won't work properly.
I also think that the autoloop buttons on the cdj won't work with timecode, because there's not any actual music coming from the timecode cd, so it won't know how long 8 beats is meant to be. There is auto loop buttons in virtual dj though, very good feature.
Pretty much all the other features should work though, scratching, loop in/out, cue points, etc.
Why not download the demo version of the software?
http://www.download.com/Virtual-DJ/3000-2170-10212112.html?part=dl-VirtualDJ&subj=dl&tag=button
and then try for yourself! :)
geposted Mon 12 Mar 07 @ 9:52 am
