Has anyone solved the problem with the LAME.DLL file.. I'm still getting the impossible to save error..
I thought it might had something to do with using windows xp and a slow laptop.. just upgraded to a Sony vaio with windows vista running @2ghz duo..with 2gb ram.. and still getting the same error..
Any suggestion other than "reducing the bit rate to 92kbps" as this works but ruins the quality of what your recording....??
P.S Credit to VDJ... Using 2ghz duo with 2gb ram ROCKS.... NO MORE SNAP CRACKLE AND POPS.
geposted Mon 12 Mar 07 @ 9:09 am
http://www.free-codecs.com/download/Lame_Encoder.htm
download and extract this into the vdj program folder
jobs a gooden ;)
jobs a gooden ;)
geposted Mon 12 Mar 07 @ 1:12 pm
Sky.... Tried your Lame.dll download.... Still getting the same problem buddy.... any other solutions...?
geposted Mon 12 Mar 07 @ 3:37 pm
could you take a screenshot for me and post it here?
geposted Mon 12 Mar 07 @ 4:11 pm
sky "for some reason i cannot post pictures the site" all i can say is when i try to save (even with update lame.dll) i get a pop up saying "impossible so save c:\users\levi\desktop\12345.mp3"
Hope this helps buddy...!
geposted Mon 12 Mar 07 @ 8:47 pm
might be an idea to try a fresh install
back up your database files from the program folder
mp3database.txt
virtualdjdatabase.xml
virtualdjdatabase(yourname).xml
now uninstal
and use philly djs reg cleaning tool.
https://virtualdj.com/addons/tools.html
and then reinstall and place back your database
and try again :)
mp3database.txt
now uninstal
and try again :)
geposted Mon 12 Mar 07 @ 10:11 pm
Tried a clean re-install and still no luck... i had this problem with xp using a toshiba laptop.. and now im using vista with a sony vaio 2ghz-duo with 2gb ram and the same results... could this be a problem with rip vinyal itself...?
geposted Mon 12 Mar 07 @ 10:46 pm
and the lamecodec is still there?
geposted Mon 12 Mar 07 @ 11:26 pm
Sky... I done a clean install (removing REG) then i installed the new lamecodec you told me to download. And im still getting the same problem buddy...!
geposted Mon 12 Mar 07 @ 11:28 pm
ok mate sorry to hear about this problem i will research this further and get back to you.
geposted Mon 12 Mar 07 @ 11:36 pm
in the mean time try this this is the lamecodec from my install
http://www.yourfilehost.com/media.php?cat=other&file=lame_enc.dll
so i know it works.
so i know it works.
geposted Mon 12 Mar 07 @ 11:41 pm
Sky Check this... When i install VDJ from scratch all at face value seems to be okay. I then launch Rip/V (locate the lame.dll as asked) hit the record button then save with no problems, other than the mp3 conversion being poor quality.. when i change the bit rate this is where the problems start. I then get the "impossible to save" error.. Now if i change the bit rate down to 92kpbs then all seems okay other than the quality of the recording is very poor. Now this was happening to me whilst i was using Windows XP on a Toshiba laptop... Now I'm using windows vista on a Sony vaio Fe41z 2ghz duo with 2gb ram and the problem remains the same.. I'm now thinking that this problem is to do with Rip vinyl itself.. Your comments please sky...? Thanks buddy...!
geposted Wed 14 Mar 07 @ 9:01 am
ok i will try it on my testing and dev machines.
geposted Wed 14 Mar 07 @ 12:55 pm
Earth calling sky do you read me over...(lol) any news on this topic buddy...?
geposted Sat 17 Mar 07 @ 3:30 pm
i am testing now:)
seems ok , even at higher bit rates
how does the recording sound for you?
geposted Sat 17 Mar 07 @ 5:55 pm
Anything below 192 starts becoming noticeable.. I have tried rip vinyl on a couple of friends machines and still getting the same results.. Keep me posted..!
HAS ANYONE ELSE OUT HERE NOTICED THIS PROBLEM....?
geposted Sat 17 Mar 07 @ 9:11 pm
