I HAVE SO MANY VIDEOS THAN WORK PERFECT IN ANY OTHER SOFTWARE BUT IN VIRTUAL DJ THE VIDO STARRT FROM THE BEGININ AND THE AUDIO 2 OR 3 SECONDS AFTER WHAT CAN I DO 4
HELP PLEASE!!!
HELP PLEASE!!!
geposted Mon 12 Mar 07 @ 7:51 pm
What are the specs for your machine? What version are you using? Is it a demo or a cracked version? What format are these videos? What is the source of the videos?
geposted Mon 12 Mar 07 @ 8:36 pm
@producingfun
Don't repeat posts, someone in the spanish forum has answered back the same question than you made here.
geposted Tue 13 Mar 07 @ 1:31 am
sorry should i continue here or the other thead
P4 2,8 512, 250
ripping from promoonly dvds in ffmpeg x xvid (mencoder) 1800 kbps 2 pass / mp3 160 48000
is any recomendatioon for ripping video
a software or any codec in particular
and for last can i become a beta tester for the mac version i have a MacBook Pro C2D 2.33, 2GB Ram
P4 2,8 512, 250
geposted Tue 13 Mar 07 @ 6:22 pm
its what the internal video decoder does with some types of video (DIVX files i think?)
you got 4 options;
dont use VDJs internal video decoder (there are others)
dont use DIVX videos (not the best, although the most common)
put up with it
wait for them to fix it
you got 4 options;
put up with it
geposted Wed 14 Mar 07 @ 12:28 am
Try using wmp decoder for some users it works better, in config go to codecs and choose it, good luck.
geposted Wed 14 Mar 07 @ 2:11 am
