how would i run this inconjunction with vdj?
geposted Sat 17 Mar 07 @ 6:51 pm
you woudlnt run it seprate and change the file names with it to the feilds are switched :)
geposted Sat 17 Mar 07 @ 9:32 pm
hi sky
sorry but need your advice or some one that has come across this problem with database updater as i said before using back up lappy as practice until main one comes back or is renewed so not bothered if there is any screw ups. i open up du go to 1) select create new database 2)select drive, chose subfolder 3) start searching files into source file,transfer files into destination box (does each file have to be ticked individually cos i cant get to tick by selecting) 4 & 5) chose which fields i want in comment line press tag info then on completion press 6.
did one folder only shows new comment line on half the folder, tried again on another folder and it does not update comment line, any help or suggestions were i'm going wrong please....Tayla
geposted Sun 18 Mar 07 @ 5:42 pm
if there are no tags it wont read them.
geposted Sun 18 Mar 07 @ 8:18 pm
