Forum: Old versions
Topic: VDJ For Radio Use
I am using the trial version for "normal" radio use. So far I am impressed, however...There are several things i would like to know if are possible before buy:
1) In order to talk, music has to be reduced, now i do it manually but he overall result is not OK. Is there any way to reduce the volume gradually and return back to max value? I didn't found such function, maybe there is a plug-in or...?
2) I don't like at all the music management of VDJ. Is there any software that could keep logs of what I am playing and suggest other songs that haven't been played for example 1 week? With so many files its hard to remember which song you played before one week and which you haven't played at all...
Kind regards to all VDJ users!
geposted Wed 14 Mar 07 @ 1:17 pm
sbangsPRO InfinityMember since 2004
for pro user there is a mic control plugin to contol volume and such
the mk2 dj console is good aslo in this setup aslo as it has a built in talk over funtion may want to check it out :)
the songs that are played turn red
for a history of what is played check the file history.txt in the program folder
vdj is updated several times a year and each update brings great new features aslo
which are free to reg users :).
hope that helps.
geposted Wed 14 Mar 07 @ 3:13 pm
