Hi just bought vdj hercules edition and want to get new laptop will vista cause any probs ? thanx djamos.
geposted Wed 14 Mar 07 @ 2:49 pm
to use the free console software with vista you need an update which is comming soon
and the console driver
if you buy pro now
at a
discount it is supported in vista
at any rate the free console version will be updated very soon
if you buy pro now
at a
geposted Wed 14 Mar 07 @ 3:09 pm
They had just released the dj console version vista compatible
3.4.1, go to your download center, and download the new version. It will be vista compatible.
Also remember to download the latest drivers from the hercules website.
geposted Thu 15 Mar 07 @ 1:16 am
Thanx guys , its all sorted now ..keep up the good work vdj.
geposted Sat 17 Mar 07 @ 8:26 am
Does Anyone know who to use the cue bottons on hercules. I want to cue one or two spots and run them back during play without stopping the track, How do i do this? Please Help.
geposted Sat 17 Mar 07 @ 11:03 pm
Go to the point where you want the cue, use the cue buttons at the top. With the Loop/Effect/Cue set to cue press the one you want to set it to. When you are playing that song, and are ready to go to that cue, select the cue option out of the three and press the corresponding button. As long as you don't hit the cue button by the play/pause button it should not stop.
geposted Tue 20 Mar 07 @ 12:44 am
