it was mentioned that it was possible to input an external source via line in to beatlock say a cd or vinyl deck..
Is this up and running yet if so how do i configure it?
Stu
Stu
geposted Tue 08 Jul 03 @ 11:59 am
You can already use the beatlock with cd using your PC cd device..
geposted Tue 08 Jul 03 @ 3:44 pm
Can it only be done from the puter cd drive at the moment?
When i run with my full set up i have a external cd drive and sometimes even a vinyl deck plugged in as well, be excellent if these could be put through the line in??
Stu
Stu
geposted Tue 08 Jul 03 @ 4:01 pm
Hmm actually i don't see any line-in config atleast in the trial version, so maybe this isn't supported after all..
geposted Tue 08 Jul 03 @ 4:53 pm
you can use a line in item with Virtual DJ. In the main folder menu, choose sound card.
I haven't tried this yet... but it's there.
I believe this will allow you to select an external device plugged into the line in on your sound card.
(unless I totally misunderstood previous posts on the issue)
geposted Tue 08 Jul 03 @ 4:56 pm
It's in the directory tree, under the desktop folder
geposted Tue 08 Jul 03 @ 5:02 pm
thanx guys, didnt think to look there!
stu
stu
geposted Tue 08 Jul 03 @ 5:38 pm
Well that seems to work well, i tried connecting the laptop and desktop VDJ together via the external extigys on both..
couldnt get it to work on line out but it works ok on the speaker outs...
its quite strange seeing the visual beat footprint on a different puter...
But its great as i can use the main puter decks as normal, a third and fourth deck or sound source for extra loops and segways and the second puter can run my winamp visuals without putting any strain on the cpu in the main one....
The more i look at it the better it gets!!
Well done team
Stu
Well done team
Stu
geposted Tue 08 Jul 03 @ 6:19 pm
