Can you use smartripper to make backups of your own dvd's?
Either music or video.
Meaning take a dvd you legally own and make a dupliate of it.
geposted Wed 14 Mar 07 @ 5:21 pm
yes, but I would just use dvd shrink/dvd decrypter
google : )
google : )
geposted Wed 14 Mar 07 @ 7:45 pm
If shrink comes up with an error and won't back it up. Smartripper will make a backup on your desktop and then you can use Nero to burn the backup dvd?
geposted Thu 15 Mar 07 @ 12:19 am
what version of shrink are u using? You could use smart ripper but the problem is you'll most likely need a dual layer dvd.
Dunno if nero will shrink it to fit a dual layer.
geposted Thu 15 Mar 07 @ 12:23 am
Gottcha.
Right now usining 3.1. For some reason 3.2 did not work.
Thanks
Thanks
geposted Thu 15 Mar 07 @ 8:44 pm
MediaCoder is also a good tool to rip + encode your DVDs !
geposted Fri 16 Mar 07 @ 10:12 am
