Forum: Old versions
Topic: VDJ Ripper doesn't work.. crashes every time
I'm having a huge problem with the VDJ ripper. In both my home and my BRAND NEW work PC the VDJ ripper will crash as soon as it TRIES to open if the is a disc in the drive already. If i put a disc in the drive after i open, then it also crashes. I've seen elsewhere that many others have this issue. Is there a solution??
MY home PC is an Emachines PC
Home Machine:
Emachines T3410 XP Home SP2
AMD3400+ Processor 2.0 ghz
1600 FSB, 256kb L2 Cache
Lite-On DVD/CDR combo Drive
NEC Combo Drive
160Gig HD
1 gig Ram
nVIDEA GeForce 6100 Video
NEW Work PC:
Intel Core 2 Duo E6600 (2.4 GHz, 4MB)
2GB DDR2-667 Memory
1 WD 80gb SATA HD (OS & programs)
1 500Gb & 1 250 Gb HD
1 Sony DVD Recorder, ADW-Q170A
Windows XP Pro
M-Audio Delta 410 Audio
ATI RADEON X1600 Pro 512MB VIDEO
geposted Thu 15 Mar 07 @ 10:46 pm
Smart Ripper for Promo Only, do a search for it here and you will find the link and the settings. If they aren't Promo Only ie. store bought dvds go with DVD decrypter.
I have smartripper, but i don't understand why the internal dvd ripper doesn't work
I don't either:)
are these copyrighted Cds?
it doesn't matter what dvd it is.. hell even the free dvd's that come in guitar magazines crash it
another question: How do i make Smartrippers VOB files Smaller. I ripped a Headbangers DVD and the tracks are an average of 300 megs each.
Just a note here. VDj will not play a file encoded with an ac3 stereo audio track. It must be mp2 or other. Also i have found that the included ripper with VDJ will not rip DVD vidoe with ac3 encoded audio files. I switched to Xilsoft DVD ripper platinum 4, and have had no problems ripping any DVD's since then. It will allow you to re-encode the ac3 audio file as an mp2 , with no audio loss. Also has alot of compression tweaks for all of you, like myself, who just don't like the presets. Hope this helps a bit.
