Hi,
WAs just wondering if VDJ plans to add a 3rd or 4th Virtual Deck in future updates to the product?
I own both Traktor 3 and VDJ 4, I preffer VDJ over Traktor as its much easier to use but having more than 2 decks would be pretty awsome.
geposted Fri 16 Mar 07 @ 10:37 am
For now, load two instances - if you have a second monitor, put one instance on the computer's own monitor and the other on the large screen.
In the Skins section, I believe there's also a "Muti-Instance" skin available, giving you the capability to work with four decks (vier, quatorze, quattro, whichever language you speak)
geposted Fri 16 Mar 07 @ 11:10 am
you can use the new skin V Mix multi-instance too
geposted Fri 16 Mar 07 @ 11:18 am
But how to you syncronice all decks with multi-instance skin????i got it only working with 2.
geposted Fri 16 Mar 07 @ 4:24 pm
