Why is it that I still get an error loading some of my karaoke files in virtula Dj that are zipped and others are ok. Also the zipped ones that dont work in virtual dj work fine in club dj pro and sax n dottys and most other players. Maybe there is a bug in the zip decode ?
Please help !
Please help !
geposted Fri 16 Mar 07 @ 4:17 pm
I've had a similar problem too. I've had zip files work, then open them up to bin files, then rezipping
with little or no compression by mp3toolz, and none of the rezipped bins worked the second time around, while all of them did work BEFORE I unzipped them.
geposted Fri 16 Mar 07 @ 4:36 pm
Just to clear things up a little, I have 130,000 karaoke mp3+g`s zipped. Some work in virtual dj and some throw up an error on the deck they are dragged to. These files that dont work will play without problems on Clubdj Pro, Sax `n Dotty, and even swift elite, therefor logic would tell you that there is a bug in the zip decoder in virtual dj which needs addressing. Maybe the zipped files that dont work have not been done with winzip, and thats where the incompatibility lies in that the zip decoder in vdj has a problems with zips done otherwise. Maybe the answer to this problem would be to introduce an option in the extention menu to use the cdg encoder in winamp instead. :)
Also can I point out that in vdj4x onwards when using the video window (windowed) so I can use my scroller on sax n dotty at bottom of the screen the video performance is abysmal, it seems they have changed the video engine from 3.4 onwards, some of us dont wand full screen where it sits on top of sax n dotty.
I hope someone sorts these 2 problems out as they are the only things that make me use sax n dotty as well.....
geposted Fri 16 Mar 07 @ 4:44 pm
