esa actualizacion para mk2y mp3 que esta en el centro de descarga es la misma que esta en la pajina de hercules.com
Installation :
1- Uninstall the previous driver version: to do so, click Start/Settings/Control Panel. Select the Add or Remove Programs icon, then uninstall Hercules DJConsole Series drivers. Alternatively, you can simply launch this package: it will uninstall the previous drivers for you.
2- Restart your PC.
3- Launch this package to install the new drivers.
4- At the end of the installation, you may be prompted to update your firmware version if you have not already updated it. Please be sure to strictly follow the on-screen instructions for this very important procedure.
5- You are now ready to use your DJ Console or DJ Console Mk2.
Contents :
Driver Package Version 3.4.0.0
DJ Console Mk2 :
DJ Console Mk2 Firmware Version 13.7
Mk2 Control Panel Version 1.2.0.8
DJ Console :
DJ Console Firmware 35
DJ Console Control Panel version 1.4.2.5
Changes :
- Windows Vista x86 (32 bits) support.
- Fixes some ASIO minor issues.
- Fixes DJ Console MK2 firmware issues for Windows Vista optimization.
- Under Windows Vista, a Virtual DJ software update is needed (Available soon).
VirtualDJ 3 free update for Vista will be released soon for DJ Console MK2
No free upgrade is planned forVirtualDJ 1 DJC Edition. Since this version is not compatible with Windows Vista, DJ Console 1 users who want to switch to this operating system must either mix with another software, as MixVibes DJC Edition (fully supported in Vista), or they should buy an upgrade of VirtualDJ.
- Under Windows XP, Virtual DJ 3 & 4 will not have monitoring working with the MK2, an update will be available soon. Because of this issue this update is not recommended for XP users.
[Windows XP / Vista x86 (32 bits) ] 6.10 MB
Installation :
2- Restart your PC.
Contents :
DJ Console Mk2 :
DJ Console :
Changes :
geposted Sat 17 Mar 07 @ 2:13 am
